How to load the base map image only what is seen in dataframe of ArcMap
4433
12
11-06-2016 11:23 AM
Ravi_Nigudkar
I have loaded the base map. I want  only the area for Austin, Texas to be loaded. Is there a way to cookie cut this out. I don't want to use Bookmark. The polygons are the zipcodes-vector data polygon feature class
See image below.
DanPatterson_Retired
or perhaps you want to use Clipping the Data Frame—Help | ArcGIS for Desktop
to ignore the stuff outside your area of interest
JayantaPoddar
Are you looking for How To: Clip data to the data frame
Think Location
Ravi_Nigudkar
Hi Jayanta,
Thanks for your help. It worked. How do then save the clip so that
everytime I load the image it loads faster.
Let me know
Ravi
curtvprice
How do then save the clip so that everytime I load the image it loads faster.
Set up a basemap cache: About ArcGIS caches—Help | ArcGIS for Desktop
Ravi_Nigudkar
Robert,
I have another question. I am not able to make my Python window work in
ArcMap. The autocompletion does not work.
ArcGIS crashes.
Can you help.
Ravi
On Sun, Nov 6, 2016 at 3:05 PM, Robert Scheitlin, GISP <[email protected]>
Ravi... you didn't report back on the auto completion on that thread... do so there please, eat thread is supposed to be one question, not a continuum
Ravi_Nigudkar
Hi Robert
My data frame issues have been resolved.
I still haven't found a solution for ArcPy problem and why the autocompletion does not work
Sent from my iPad
Ravi_Nigudkar
So how do you do that. ? I am new to to Geonet.
You have updated your other thread on autocompletion.  Chec it again.  Just try to keep one type of question in one thread.  There are many documents on the Community Space page to help you familiarize yourself with GeoNet and how to get around and work with documents etc etc.
https://community.esri.com/community/help-and-feedback
