Need help with a calculate Python Print Statement script for ArcMap
1161
11-05-2016 08:38 AM
Noah_McLaughlin
To finish off my script tool i want the script to give me an add message (sum) that calculates total hectares for only 2 certain attributes (soil classes 1 and 2) in my Hectares field. I have a hectares field and a field that give soil classes 1 to 5. in the python language how would i write the expression?
The shapefile i want to perform this on is called: [clip_output]
The field thats lists soil type is called: [CLASS]
The hectares field that I want the script to give me the sum from is called [Hectares]
This is what I have so far but it is not working (not sure if i need to list variables):
with arcpy.da.SearchCursor(clip_output, ['Hectares'], 'CLASS in (1, 2)') as cur:
   sum = 0
   for row in cur:
      sum += row[0]
arcpy.AddMessage(sum)
error im getting is:
line 106, in <module> for row in cur: RuntimeError: An invalid SQL statement was used
JoshuaBixby
MVP Esteemed Contributor
Is CLASS a string or number field?  If the former, it will generate the same error you are seeing when you try to treat it like a number, which you are doing.  If the field is a string, try the following:
with arcpy.da.SearchCursor(clip_output, ['Hectares'], "CLASS in ('1', '2')") as cur:
JoshuaBixby
