BUG?: Select Widget not zooming
2498
13
11-04-2016 03:56 AM
deleted-user-CQZbjNeBXm49
Hi All,
1.   I don't if I am the only person experiencing this, but when I do a "Select by Polygon or rectangle" on a set of       "Mapserver\Dynamic Layer(s)" and create a "Feature Layer" from the selection, the original layer's box gets       "unchecks" but still remains rendering on the map.
2.   Also after the feature layer has been created, when I click on that layer's  "zoom to" it gives an error message, see image below:
Kindly guide a person in need (me   )
Thank you
Baba
RobertScheitlin__GISP
Baba,
   I tested what you are mentioning here and I had no such issue on my end.
Hi Robert,
Both?
So what might cause that?, maybe this is due to the custom widget (LL)?.
Cheers
Baba,
    I don't think it is the LL widget but you can test by removing it and see if you have a similar issue.
Robert,
But this is also the case on ArcGIS Online, the "Zoom to" does not work
Also the "Legend" of the created layer (selection) does not print
On ArcGIS Online
Baba
Baba,
   Then it sounds like a bug you need to report the esri tech support then.
Robert,
How do I go about that?, I have never had to do one before, do I just give "Tech Support" a call and report the bug?
Baba
Yep, Just explain the issue and how to reproduce.
Thanks Robert,
I have now logged it with "Support"
Baba
by Anonymous User
Not applicable
Some thing is not correct with you service extent level.
Check this
map = new Map("map", {
basemap: "topo",
center: [-77.036, 38.891],
zoom: 16
