Multiple Photos for a Question
1464
11-01-2016 10:55 AM
by Anonymous User
Not applicable
I would like to attach multiple photos to a question in Survey123. I have put the photo files in the media folder and I type the image names in the media::Images column, but I am unable to get both images to appear. If i try just entering one image it works! I figure i must be using the wrong formatting. Any ideas to include two images in the media::Images column?
JamesTedrick
Esri Esteemed Contributor
Survey123 only supports 1 image to accompany a question.  I would suggest trying to combine the images together using a image editing tool if you have 2 images.  If this is a select_one or select_multiple, 1 image per answer is also supported in the choices tab.  From a visual layout perspective, you could have a note immediate before the question that has the image as well.
