Locally Hosted GeoForm Errors : Property '3' of null
1108
10-31-2016 07:55 AM
BrianO_keefe
Honored Contributor
So I've begun (what I fear will be) the (laborious and excruciatingly painful) process of propping up a locally hosted GeoForm for the Events Permit Solution.
I've created the Events Permit AGOL Webmap.
I've shared it with EVERYONE.
I've configured the GeoForm with the web ID.
It spins when I load it... and the Console error says:
Any ideas? I'm completely lost.
BrianO_keefe
Honored Contributor
I cleaned up the default.js attribute 'sharinghost' to point to my arcgis portal and now I'm getting:
Unable to create map: A valid layer to create the GeoForm was not found. If the GeoForm has been configured with a layer, the layer may no longer be available, or authorization failed.
So lost...
BrianO_keefe
Honored Contributor
Ok... I had to go into dev tools on Chrome in order to get the Layer ID. Once I did that... it worked. Putting 'all' did NOT work.
KellyGerrow
Esri Alum
HI Brian,
Can you share your web map? Is there an editable point layer in the web map?
-Kelly
BrianO_keefe
Honored Contributor
GeoForm
There is and has been.
