Collector crashes when opening webmap with Custom URL to send fields from Collector to Survey123
1433
10-20-2016 12:50 PM
CarlHolt1
Using the custom URL I am able to pull over a couple of fields from the WebMap into Survey123 on my desktop, but when I go to open that same map on Collector the application crashes. I am able to open up other webmaps and if I remove the survey feature service from the webmap, I can open the webmap in collector. Is the feature service corrupt or is the custom URL throwing it off.
Custom url: arcgis-survey123://?itemID=8252e36976a14a7580831ddfb26ee665&field:sw_id={SW_ID}&field:name_dev={Developmen}
iPad iOS v8.0.2
Collector for ArcGIS v 10.4.0
Survey123 v1.8.21
IsmaelChivite
Esri Notable Contributor
To close this question, the source of the Collector crash was  identified. More details in this other thread.
OscarSepulveda_III
This discussion from the Collector message board provides some insight into our problem that is similar to yours.  I believe this is what we are dealing with..
https://community.esri.com/thread/183513-does-collector-deeplinking-no-longer-work-in-ios10
IsmaelChivite
