Converting from GraphicsContainer to Polygon Feature
1818
10-19-2016 06:40 AM
ScottHall1
I have a problem with ArcObjects trying to convert a graphics container filled with segments into a polygon to insert into a feature class. In order to make the jump from a graphics element to a polygon, I believe I have to go from an element to a segment collection that can be inserted into a feature class.
My routine can insert the segments, but the feature class creates a polygon that is missing segments from the beginning or end of the object chain.
        public void FinalizeObject(IFeatureLayer layer, IGraphicsContainer graphicsContainer)
            ISegmentCollection segmentCollection = new PolygonClass() as ISegmentCollection;
            try
                graphicsContainer.Reset();
                IElement element = graphicsContainer.Next();
                ISegmentCollection tmp = new PolygonClass();
                while (element != null)
                    IGeometry geometry = element.Geometry;
                    ISegmentCollection tempClass = new PolygonClass() as ISegmentCollection;
                    tempClass = geometry as ISegmentCollection;
                    if (tempClass != null && tempClass.SegmentCount > 0)
                        for (int x = 0; x < tempClass.SegmentCount; x++)
                            ISegment segment = tempClass.Segment[x];
                            segmentCollection.AddSegment(segment);
                            segmentCollection.SegmentsChanged();
                IFeatureClass featureClass = layer.FeatureClass;
                IFeature feature = featureClass.CreateFeature();
                feature.Shape = (IPolygon)segmentCollection;
                feature.Store();
            catch (NullReferenceException nre)
                MessageBox.Show(nre.ToString());
I am breaking it down and piecing it back together because I don't know if there is a way to take the entirety of a graphics container as a single usable object, hence having to loop through the container and piecing it into a segment collection.
What am I missing? Thank you for any help.
DuncanHornby
MVP Notable Contributor
Can you amend your question and show some example images of the sorts of graphics you are trying to convert into polygons in a featureclass.
