loading unsafe code message
2802
10-07-2016 07:09 AM
RicardoRodriguez2
Hello
I'm using a story into my presentation and I'm having this message:
I added the link obtained from:
Into the url panel.
The url is directed to an Esri domain, I guess.
If I authorize the scripts to execute, the story works fine.
OwenGeo
Esri Notable Contributor
Hi Ricardo,
It looks like your main story is a Cascade -- do you have any other web content embedded in that story? Has the Map Tour been modified with any HTML?
Can you share the links to your Cascade story and the Map Tour you are trying to embed so we can take a look?
Owen
Owen Evans
RicardoRodriguez2
Hi Owen
I was reading some references and could be the certificate in the domain.
And this is the embedded Web Map app, which is sending the warning.
This is the link: http://arcg.is/2cZmGuR
Here are some of the external links:
https://www.youtube.com/embed/tkDbcrSjaEk
http://www.gainhealth.org/wp-content/uploads/2014/02/impact_02-150x150.jpg
http://www.gainhealth.org/wp-content/uploads/2014/03/Mozambique_country_350x3501.jpg
Could be that the links not using a https connection are the reason of the warning message.
Or
If I try to run another instance in Microsoft Edge,
https://earthimagery2.maps.arcgis.com/home/signin.html?returnUrl=http%3A//earthimagery2.maps.arcgis.com/apps/MapTour/index.html%3Fappid%3D60de0aa94c0d435da7032aa756f59858
It requires to be logged . None of the WMA are shared.
Please let me know if you need to share these two apps and at what level, Organization or Public.
These are the options that I have:
The user that I’m using is ricardor911_eiaw.
Thank you.
De: Owen Evans
Enviado el: Monday, October 10, 2016 3:36 PM
Para: Ricardo Rodriguez
Asunto: Re: - Re: loading unsafe code message
<https://community.esri.com/?et=watches.email.thread> GeoNet
reply from Owen Evans <https://community.esri.com/people/OEvans-esristaff?et=watches.email.thread> in Story Maps - View the full discussion <https://community.esri.com/message/639961-re-loading-unsafe-code-message?commentID=639961&et=watches.email.thread#comment-639961>
