Spatial Reference issue
1746
10-07-2016 09:27 AM
KennethKirkeby
I received a project with a shapefile from another department.  When I try and load it into ArcMap 10.2.1, I receive the following:
Properties:
Just looking for some direction on how to resolve. I understand the distinction between Geographic Cood. Sys. vs Projections but I'm struggling to identify, if this is my issue.
DanPatterson_Retired
Looks like someone used the define projection tool, and defined it as a geographic coordinate system (GCS wgs84)
And given the extents that is totally absurd.  Since it was a shapefile, locate the *.prj file and rename it to *.xxx and reload the shapefile.  It will probably load but it will tell you it doesn't have a defined projection.
Perhaps someone meant to give it a Web Mercator projection instead if you are using webby data sources
