Perform Raster Calculation from Multiple Sub-folder Using ArcPy
8509
23
10-07-2016 05:14 AM
ShouvikJha
I have five subfolders with Rasters name with the same parameter. I am trying to figure out a way to Loop average of all  raster and save output raster in outfolder . For instance
Subfolder1   Subfolder2   Subfolder3   Subfolder4    Subfolder5   Outfolder
r001_NPP.tif r001_npp.tif r001_NPP.tif r_001_NPP.tif r001_NPP.tif r001_MEAN_NPP.tif‍‍‍‍‍‍
I have tried to write code for this, Below i post my code what i have so far
import arcpy, os, glob
ws1 = glob.glob(r'D:\subfolder1\*.tif')
ws2 = glob.glob(r'D:\subfolder2\*.tif')
ws3 = glob.glob(r'D:\subfolder3\*.tif')
ws4 = glob.glob(r'D:\subfolder4\*.tif')
ws5 = glob.glob(r'D:\subfolder5\*.tif')
outws = r'D:\outfolder'
for r in ws1, ws2, ws3, ws4:
    basename = os.path.basename(r).split("_")[0]
    r1 = arcpy.sa.Raster(os.path.join(ws1, basename + "r_NPP.tif"))
    r2 = arcpy.sa.Raster(os.path.join(ws2, basename + "r_NPP.tif"))
    r3 = arcpy.sa.Raster(os.path.join(ws3, basename + "r_NPP.tif"))
    r4 = arcpy.sa.Raster(os.path.join(ws4, basename + "r_NPP.tif"))
    r5 = arcpy.sa.Raster(os.path.join(ws5, basename + "r_NPP.tif"))
    result = (r1 + r2 + r3 + r4 + r5) / 5
    outname = basename + "r_Mean_NPP.tif"
    result.save(os.path.join(outws, outname))‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
XanderBakker
Esri Esteemed Contributor
I can't reproduce the error you mentioned. I did encounter some other errors that should be corrected like:
  • include import os at beginning of script and
  • change "out_workplace" into "out_workspace"
import arcpy
import os
arcpy.CheckOutExtension("spatial")
# generate list of rasters
##workspace = r"D:\TEST"
##out_workplace = r"D:\TEST\MEAN_NPP"
workspace = r"C:\GeoNet\MeanRasters\Case20161009"
out_workspace = r"C:\GeoNet\MeanRasters\Case20161009\MEAN_NPP"
for ras_num in [str(i).zfill(3) for i in range(1, 13)]:
    print ras_num
    rasters = []
    walk = arcpy.da.Walk(workspace, datatype="RasterDataset", type="TIF")
    for dirpath, dirnames, filenames in walk:
        for filename in filenames:
            if ras_num in filename:
                rasters.append(os.path.join(dirpath, filename))
    # calculate mean
    if len(rasters) > 0:
        print "Calculating mean of rasters: ", ', '.join(rasters)
        ras_mean = arcpy.sa.CellStatistics(rasters, "MEAN")
        ras_mean.save(os.path.join(out_workspace, 'r{0}_MEAN_NPP.TIF'.format(ras_num)))
    else:
        print "no rasters for ras_num", ras_num‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
This created the mean raster for ras_num 001 to 005, see attached ZIP with resulting rasters
curtvprice
I would look into arcpy.da.walk() to generate the list of rasters, and use the Spatial Analyst Cell Statistics tool on the raster list.
Walk—Help | ArcGIS for Desktop
Cell Statistics—Help | ArcGIS for Desktop
Cell Statistics is much more efficient, especially with long lists of rasters -- and it also has a very handy DATA/NODATA option so null is treated as zero in the cell by cell summation.
Untested code:
import arcpy
from arcpy.sa import *
workspace = r"D:\"
rasters = []
# calculate mean
sum = CellStatistics(rasters, "MEAN")
sum.save(os.path.join(out_workspace, "npp_sum.tif")‍‍‍‍‍‍‍‍‍‍‍
ShouvikJha
Thank you. I have updated my suggested by you, problem still persist, i am not understanding how to iterate through each folder, take all series of 001_NPP from all folder and calculate average oh them and save it as 001_NPP_MEAN, below is my updated code and along with code i have attached reference raster also which i am using for my raster calculation,
import arcpy
out_workplace = "D:\TEST\MEAN_NPP"
rasters = []
# calculate mean
sum.save(os.path.join(out_workspace, "npp_sum.tif")‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
DanPatterson_Retired
your code is only minimally updated from what Neil provided and it was untested.
What was the error message?
issues to get you started...
  • Line 13 is not indented properly
  • Walk—Help | ArcGIS for Desktop you need to check the correct format
  • datatype and type in Walk are incorrect
  • you shouldn't use from X import *
You need to provide some input to the solution and to do that providing commentary as to what went wrong and where would go a long way
ShouvikJha
Dan . thanks , you are right. I didn't post the error massage. Line no 13 i am getting the Indentation Error massage. I tried to fix it but not solved yet. error massage below
File "<module1>", line 13
IndentationError: expected an indented block
Ok.... add four (4) more spaces to the beginning of line 13 so it is indented properly
Here is the python style guide recommendations PEP 8 -- Style Guide for Python Code | Python.org
ShouvikJha
Dan , thanks . I have solved the indentation error, and i updated my code but still i could not solve the problem, updated code below
error masage
ile "<module1>", line 18
    sum.save(os.path.join(out_workspace, 'r{0}_MEAN_NPP.TIF'.format(ras_num)
SyntaxError: invalid syntax
Updated Code
import arcpy
for ras_num in [str(i).zfill(3) for i in range(1, 12)]:
 rasters = []
# calculate mean
RebeccaStrauch__GISP
Change line 7 to
You missed the "r" in that path.
XanderBakker
In addition, line 18 is missing 2 closing brackets "))" at the end of the line. Perhaps you didn't copy the entire line.
curtvprice
Hey no fair. 😉
