I have five subfolders with Rasters name with the same parameter. I am trying to figure out a way to Loop average of all raster and save output raster in outfolder . For instance
Subfolder1 Subfolder2 Subfolder3 Subfolder4 Subfolder5 Outfolder r001_NPP.tif r001_npp.tif r001_NPP.tif r_001_NPP.tif r001_NPP.tif r001_MEAN_NPP.tif
I have tried to write code for this, Below i post my code what i have so far
import arcpy, os, glob
arcpy.CheckOutExtension("Spatial")
ws1 = glob.glob(r'D:\subfolder1\*.tif')
ws2 = glob.glob(r'D:\subfolder2\*.tif')
ws3 = glob.glob(r'D:\subfolder3\*.tif')
ws4 = glob.glob(r'D:\subfolder4\*.tif')
ws5 = glob.glob(r'D:\subfolder5\*.tif')
outws = r'D:\outfolder'
for r in ws1, ws2, ws3, ws4:
basename = os.path.basename(r).split("_")[0]
r1 = arcpy.sa.Raster(os.path.join(ws1, basename + "r_NPP.tif"))
r2 = arcpy.sa.Raster(os.path.join(ws2, basename + "r_NPP.tif"))
r3 = arcpy.sa.Raster(os.path.join(ws3, basename + "r_NPP.tif"))
r4 = arcpy.sa.Raster(os.path.join(ws4, basename + "r_NPP.tif"))
r5 = arcpy.sa.Raster(os.path.join(ws5, basename + "r_NPP.tif"))
result = (r1 + r2 + r3 + r4 + r5) / 5
outname = basename + "r_Mean_NPP.tif"
result.save(os.path.join(outws, outname))
I can't reproduce the error you mentioned. I did encounter some other errors that should be corrected like:
import arcpy
import os
arcpy.CheckOutExtension("spatial")
# generate list of rasters
##workspace = r"D:\TEST"
##out_workplace = r"D:\TEST\MEAN_NPP"
workspace = r"C:\GeoNet\MeanRasters\Case20161009"
out_workspace = r"C:\GeoNet\MeanRasters\Case20161009\MEAN_NPP"
for ras_num in [str(i).zfill(3) for i in range(1, 13)]:
print ras_num
rasters = []
walk = arcpy.da.Walk(workspace, datatype="RasterDataset", type="TIF")
for dirpath, dirnames, filenames in walk:
for filename in filenames:
if ras_num in filename:
rasters.append(os.path.join(dirpath, filename))
# calculate mean
if len(rasters) > 0:
print "Calculating mean of rasters: ", ', '.join(rasters)
ras_mean = arcpy.sa.CellStatistics(rasters, "MEAN")
ras_mean.save(os.path.join(out_workspace, 'r{0}_MEAN_NPP.TIF'.format(ras_num)))
else:
print "no rasters for ras_num", ras_numThis created the mean raster for ras_num 001 to 005, see attached ZIP with resulting rasters
I would look into arcpy.da.walk() to generate the list of rasters, and use the Spatial Analyst Cell Statistics tool on the raster list.
Walk—Help | ArcGIS for Desktop
Cell Statistics—Help | ArcGIS for Desktop
Cell Statistics is much more efficient, especially with long lists of rasters -- and it also has a very handy DATA/NODATA option so null is treated as zero in the cell by cell summation.
Untested code:
import arcpy
from arcpy.sa import *
workspace = r"D:\"
rasters = []
# calculate mean
sum = CellStatistics(rasters, "MEAN")
sum.save(os.path.join(out_workspace, "npp_sum.tif")
Thank you. I have updated my suggested by you, problem still persist, i am not understanding how to iterate through each folder, take all series of 001_NPP from all folder and calculate average oh them and save it as 001_NPP_MEAN, below is my updated code and along with code i have attached reference raster also which i am using for my raster calculation,
import arcpy
out_workplace = "D:\TEST\MEAN_NPP"
rasters = []
# calculate mean
your code is only minimally updated from what Neil provided and it was untested.
What was the error message?
issues to get you started...
You need to provide some input to the solution and to do that providing commentary as to what went wrong and where would go a long way
Dan . thanks , you are right. I didn't post the error massage. Line no 13 i am getting the Indentation Error massage. I tried to fix it but not solved yet. error massage below
File "<module1>", line 13
IndentationError: expected an indented block
Ok.... add four (4) more spaces to the beginning of line 13 so it is indented properly
Here is the python style guide recommendations PEP 8 -- Style Guide for Python Code | Python.org
Dan , thanks . I have solved the indentation error, and i updated my code but still i could not solve the problem, updated code below
error masage
ile "<module1>", line 18
sum.save(os.path.join(out_workspace, 'r{0}_MEAN_NPP.TIF'.format(ras_num)
SyntaxError: invalid syntaxUpdated Code
import arcpy
for ras_num in [str(i).zfill(3) for i in range(1, 12)]:
rasters = []
# calculate mean
Change line 7 to
You missed the "r" in that path.
In addition, line 18 is missing 2 closing brackets "))" at the end of the line. Perhaps you didn't copy the entire line.
