Write String to txt file
2927
5
10-06-2016 10:17 AM
jaykapalczynski
Honored Contributor
I have a string that is being created from a listdir.  It is Comma delimited...
I want to write this to the txt file as separate lines.  NOTING that each time I run this there will a different number in the list.  So I cannot count on any indexing etc.
What can I do to write this to separate lines one for each of the files located from the listdir?
THANKS
Code:
#...snip
dir_src = "C:\\users\\tjv36463\\Desktop\\BearCollar\\NewFiles\\"
from os import listdir
from os.path import isfile, join
onlyfiles = [f for f in listdir(dir_src) if isfile(join(dir_src, f))]
onlyfiles2 = str(onlyfiles)
file = open("log.txt", 'w')
file.write(onlyfiles2)
file.close()
#...snip
Result:
['rangedate_D032495_20160822124736.txt', 'rangedate_D032498_20160822125645.txt', 'rangedate_D032499_20160822125129.txt', 'rangedate_D032500_20160822125032.txt', 'rangedate_D032501_20160822125559.txt', 'rangedate_D032502_20160822125356.txt', 'rangedate_D033108_20160822125458.txt']
Im looking for:
DarrenWiens2
There may be a better way than this, but you can manually insert line break characters at the end of each write statement. Below will result in different lines but no commas. The commented option will add a comma to every line, including the final line. You could add a little extra logic to check if you're at the final item in the list and not add a comma.
for onlyfile in onlyfiles:
    file.write(str(onlyfile) + '\n') # or ',\n' if you want the trailing comma
file.close()
DarrenWiens2
file.close()
XanderBakker
Esri Esteemed Contributor
Or if you want it to apear as a "list object" with items on each line, replace ',' with ',\n' in variable onlyfiles2.
So write onlyfiles2.replace(',', ',\n') instead
jaykapalczynski
Honored Contributor
Thanks Darren....quick and painless...I was trying this to the variable with no success...perfect....Cheers
ChristianWells
You could use a replace function to change your commas to new line characters:
ls = ['rangedate_D032495_20160822124736.txt', 'rangedate_D032498_20160822125645.txt', 'rangedate_D032499_20160822125129.txt', 'rangedate_D032500_20160822125032.txt', 'rangedate_D032501_20160822125559.txt', 'rangedate_D032502_20160822125356.txt', 'rangedate_D033108_20160822125458.txt']
print str(ls).replace(',', '\n')
#Output:
#If you want to replace the square brackets we can handle that as well:
print str(ls).replace(',', '\n').replace('[', '').replace(']', '')
#Another option:
for i in ls:
    print i
#Output:
jaykapalczynski
Honored Contributor
Thanks Christian....very helpful...much appreciated.
