Use Manage Tile Cache to create cache for map service
1394
10-05-2016 09:37 PM
ModyBuchbinder
I would like to create one cache from a few data sources to use in mobile application.
The data sources include some local (vector and raster) data and Map service.
The docs say that the mxd for the Managed Tile Cache cannot include map service.
When I test it – it just works without any problem (cache is created).
Is it a real limitation? Why does it work? Is there any better way to do it?
I need to set an area of interest (the mobile does not need to full extent).
I am using 10.3.1
by Anonymous User
Not applicable
In this case you have need to set the map extent as per mobile application use map service
In capabilities enable Mobile Data Access...
