Tuple Error Insert Cursor
3557
7
10-03-2016 12:37 PM
ZacharyHart
Honored Contributor
My brain is fried...if anyone can/wants to modify the title of the post please do so. I'll attempt to post this w/o giving the background of the tool...if that is necessary I'll happily provide it. Here is my code:
import arcpy, os, sys, math
#Environment settings
outGDB = arcpy.env.scratchGDB
arcpy.env.workspace = outGDB
#Local Variables
#startingPt = arcpy.GetParameterAsText(0)
#sampleNumber = int(arcpy.GetParameterAsText(1))
#interDist = int(arcpy.GetParameterAsText(2))
startingPt = "startingPoints"
interDist = 660
outName = "cruisePoints"
#Create target point FC
sr = arcpy.Describe(startingPt).spatialReference
outPoint = arcpy.CreateFeatureclass_management(outGDB,outName,"POINT","","","",sr)
arcpy.AddField_management(outPoint, "CLUSTER_ID", "TEXT", "", "", "", "", "NULLABLE", "NON_REQUIRED", "")
arcpy.AddField_management(outPoint, "PLOT_ID", "TEXT", "", "", "", "", "NULLABLE", "NON_REQUIRED", "")
#Open Insert Cursor
insert = arcpy.da.InsertCursor(outPoint,["SHAPE@XY","CLUSTER_ID","PLOT_ID"])
fields = ["SHAPE@X", "SHAPE@Y", "OID@"]
with arcpy.da.SearchCursor(startingPt, fields) as cursor:
    for row in cursor:
       #Set Start points
       startX = row[0]
       startY = row[1]
       cluster = row[2]
       print(startX,startY)
       #Calculate quadrant points
       northX = row[0]
       northY = row[1] + interDist
       print(northX, northY)
       eastX = row[0] + interDist
       eastY = row[1]
       southX = row[0]
       southY = row[1] - interDist
       westX = row[0] - interDist
       westY = startY
       start = arcpy.Point(startX, startY)
       print(start)
       north = arcpy.Point(northX, northY)
       east = arcpy.Point(eastX, eastY)
       south = arcpy.Point(southX, southY)
       west = arcpy.Point(westX, westY)
       insert.insertRow([start,row,cluster])
       insert.insertRow([north,row,cluster])
       insert.insertRow([east,row,cluster])
       insert.insertRow([south,row,cluster])
       insert.insertRow([west,row,cluster])
del cursor
When pasting into the Python Console in Desktop I get the following error (note the third print as well)
JoshuaBixby
MVP Esteemed Contributor
What if you try
insert.insertRow([(startX, startY),row,cluster])‍‍
instead of
insert.insertRow([start,row,cluster])‍‍
and do similar with the other entries.
You created the insert cursor using SHAPE@XY, but you are trying to pass an arcpy.Point object instead of a tuple representing an X, Y.
JoshuaBixby
What if you try
instead of
ZacharyHart
Honored Contributor
bixb0012 Thanks for the response. I tried the modification (and I see your point now...no pun intended), but I'm still getting the same error:
Below is a portion of the code, line 48 from the error is line 27 below.
#Open Insert Cursor
    for row in cursor:
       #Set Start points
       startX = row[0]
       startY = row[1]
       cluster = row[2]
       northX = row[0]
       eastY = row[1]
       southX = row[0]
       westY = row[1]
       #start = arcpy.Point(startX, startY)
       #print(start)
       #north = arcpy.Point(northX, northY)
       #east = arcpy.Point(eastX, eastY)
       #south = arcpy.Point(southX, southY)
       #west = arcpy.Point(westX, westY)
       insert.insertRow([(startX,startY),row,cluster])
       insert.insertRow([(northX,northY),row,cluster])
       insert.insertRow([(eastX,eastY),row,cluster])
       insert.insertRow([(southX,southY),row,cluster])
       insert.insertRow([(westX,westY),row,cluster])
Dan_Patterson‌ I'm glad I finally found your codeblock formatting write-up! Thanks for that...it was driving me nuts posting stuff as a quote before.
NeilAyres
I am not sure that this is going to work :
#Open Insert Cursor
The result of the CreateFeatureclass will be a result object, not necessarily a pointer to the table on disk.
Rather set outPoint explicitly.
Like
outPoint = os.path.join(outGDB, outName)
NeilAyres
But, having looked at that again, I think Joshua is right.
Why are you pushing the value of row which is a tuple of the entire data row, into the attribute CLUSTER_ID?
ZacharyHart
Honored Contributor
Neil Ayres
Ok, so now we get to the background. I have another script which creates points spaced at a regular interval. These are the 'starting points' for field sampling. The field tech navigates to that location, does the sampling work, and then has 4 other points associated with the particular starting point which they need to conduct the same work at. A total of 5 points. These five points constitute a 'cluster'. The points in each each cluster need to be identified/associated with the cluster ("CLUSTER_ID"), but also have a unique value ("PLOT_ID"); concatenating the two would give you a unique value for each point for the entire project.
FWIW, the error raised has to do with 'value 1' which seems to be the XY.
Anyway, here's a graphic of what I'm trying to achieve.
ZacharyHart
Honored Contributor
Neil Ayres
I understand what you guys are getting at now regarding the 'row' (doh!). I've modified the inserts, and the script now runs correctly!
Can I get some guidance as to who to mark as the correct answer here? Everyone helped in one way or another. Should I modify the title of the post at all to better reflect what was going on here?
Thanks so much!
#Local Variables
interDist = 660
sr = arcpy.Describe("frontier").spatialReference
#Open Insert Cursor
    for row in cursor:
       #Set Start points
       startX = row[0]
       startY = row[1]
       cluster = row[2]
       northX = row[0]
       eastY = row[1]
       southX = row[0]
       westY = row[1]
       insert.insertRow([(startX, startY),cluster,"1"])
       insert.insertRow([(northX, northY),cluster,"2"])
       insert.insertRow([(eastX, eastY),cluster,"3"])
       insert.insertRow([(southX, southY),cluster,"4"])
       insert.insertRow([(westX, westY),cluster, "5"])
del cursor‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
JoshuaBixby
Regarding giving credit and marking correct answers, it isn't always straightforward.  I think most people would say mark the response that was most helpful (judgment call, obviously) correct and mark the other ones helpful.  If it is too difficult to pick one over the others, think about marking the first equally helpful one as correct.  If even that doesn't feel right, mark all of the helpful ones as helpfuls and the question as "assumed answered."
