how do I convert an object id to a number
3260
10-04-2016 10:11 AM
KristineKosnik
I need to convert the FID to a number in field calculator.
JoeBorgione
FID = shapefile.  OID = feature class.
Both are internally managed by ArcGIS, so you can't edit them.  They are numbers by the way;  you can add a long integer field and calc it to equal the FID or OID, but not the other way around.
JoeBorgione
ChrisDonohue__GISP
Visuals for the solution jborgion  offered:
Chris Donohue, GISP
