Standardize kernel density data?
573
12-13-2010 08:27 AM
ElizabethPhillips
Hi there,
I have transect survey data with animal counts that I successfully calculated kernel density for.  However, there are >20 transects total, and in some areas (not all), multiple transects were conducted.  Thus, the densities for these areas are inflated.  I would like to standardize my data for number of transects conducted within a certain cell.
I have pondered this and tried a few things.  First, I tried to extract the kernel density raster and join to the table with transect data.  However, this doesn't work as my original table has >18,000 points, and the raster extraction then tries to match to each point.  Is there a way to extract kernel densities and match to the metadata (e.g., transect name)?  I don't think so, given how kernels work...
My next thought was to calculate kernel densities for each individual transect (>20), and then try to calculate mean density for all transects within cells.  However, I got stuck with this, as the cell statistics only seem to allow input of two different rasters at a time.
I suppose I could calculate mean # animals/transect in advance, but each point is an individual location, and I would have to first bin the data into cells (say, 3-km), which I'm trying to avoid (unless anyone has advice on an easy way to do this!)...
Does anyone have any other ideas?
Thanks in advance...
LynGarrah
Hi Elizabeth,
It has been a while since you posted your question.  I am in a similar situation, with road mortality data on one road over 4 years but with different survey efforts in each of the four years of my data set.  Did you figure out how to standardize kernel density layers?  I would like to add my layers together to find the worst road mortality locations over the four years, but I do not want to bias those locations toward the years with more survey efforts.
