Is there a widget to query and display Hosted Feature Services and attachments?
1233
09-21-2016 03:42 PM
TL2
The query works great when adding a rest end point url to query for features.  I am looking for a widget to query a hosted feature service and show photos (attachments) from a hosted feature service from survey123.
This would provide a great interactive way to lookup and display my surveys/reports.
Does anyone know of a query type widget that also displays images (such that you do not have to select a feature to see the image like a pop-up, just query to get results)?
DerekLaw
Esri Esteemed Contributor
Hi Tucker,
By "widget", I believe you are referring to widgets in Web AppBuilder for ArcGIS, right?
As you mentioned, currently the way to view images that are part of a hosted feature layer (collected from Survey123 for ArcGIS) is to select a feature in the Web AppBuilder map display and viewing its pop-up. There are no out-of-the-box widgets that can directly query the images associated with surveys. This will require a some custom development.
You may want to try posting your question in this GeoNet discussion group, Web AppBuilder Custom Widgets
Hope this helps,
