How do I run a SQL-style UPDATE operation in GIS?
3452
6
09-20-2016 08:16 AM
by Anonymous User
Not applicable
 I want to join a layer in ArcServer to a layer in another DB (that part's easy). Then do an UPDATE [attribute x] where table1.ID=table2.ID kind of thing. Merge won't allow a table. Thanks in advance!
forestknutsen1
Are you using sde? If so what about using a database tool (we use TOAD) and just modify the table outside of Arc. It is safe as long as your tables are not versioned or if they have no add/delete tables. Or you could use arcpy with ArcSDESQLExecute and do the same thing.
by Anonymous User
Not applicable
I am trying to do it from SQL Management Studio now which is the same, functionally, as TOAD. My tables are registered as versioned tho so they are editable. Why is that a problem?
George_Thompson
Esri Notable Contributor
JoeBorgione
Is it a one to one relationship?  If so you could use a temporary join to do what you want.  SInce I don't know how the table you want want to attribute is defined, you may need to add a field (or more) to hold the data you need.
by Anonymous User
Not applicable
I can do a join, but that won't allow me to do a bulk UPDATE operation.
JoeBorgione
I'm not sure that SSM is the tool to use with a versioned database;  you may run into some problems with that.
