Georeferenced map from DavidRumsey.com producing error "KML To Layer" operation
3143
7
09-20-2016 12:15 PM
DanikaCooper
I'm working with a Georeferenced map from DavidRumsey.com. It is saved as a .kmz file, but I keep getting "ERROR 000401: No features were found for processing Failed to execute (KMLToLayer)" when I attempt to convert the .kmz file to a layer. Any thoughts on how one might fix this?
DarrenWiens2
I just downloaded a KMZ from the site, saved as KML, opened in text editor, and see that I haven't saved the data at all, but a network link to the data back on the original server. I suspect that's the problem, sort of like how you can't run geoprocessing tools on a web mapping service. Is there any way to actually download the raw data from the site?
DanPatterson_Retired
is it a case of include ground overlays KML To Layer—Help | ArcGIS for Desktop
JayantaPoddar
Can you open it in Google Earth?
Think Location
DanikaCooper
@Dan Patterson: I tried both options of including and excluding ground overlays. Both produced the same error.
@Jayanta Poddar: Yes, the image will open in Google Earth and is georeferenced properly.
can you make kml files out of the contents... perhaps it is one of the bits if it is a composite
DanikaCooper
I can only save a .kmz file from DavidRumsey.com. I've tried opening .kmz
file in Google Earth and saving as .kml; then running KML To Layer as well
as just running KML To Layer on .kmz file. Neither works.
welll, it is either something with the site, how and what arcmap handles the file or what you are trying to download.
If the site download for the most simple thing works in google and arcmap, then it is what you want that is the issue.
I am not on an Arc* machine so I can't test.
DarrenWiens2
