Adding z values from points to line
10368
10
09-20-2016 01:15 AM
SBreckan
I have two lines (the center line of a tunnel) that lack z values, they are currently just flat lines with start and end xy values. I do have the z values in points - but how do I get the values from the points to the lines? I have the basic license and cannot use the Split Line at Point tool.
I would like the lines to be split at each point and assigned a z value. I have two lines and approximately 400 points, the elevation of the tunnel differs between a few meters below sea level and 90 meters above.
I am using arcmap for desktop 10.3.1
Thanks in advance.
DanPatterson_Retired
did you try Points To Line—Help | ArcGIS for Desktop
or in an edit session Snapping points to lines—Help | ArcGIS for Desktop
or what have you tried?
SBreckan
I have tried Points to line, the result is a line that matches the original line I have, with an attribute table with only objectID, shape and shape length.
Snapping points to line I cannot use unfortunately as I only have the Basic license.
I have tried Spatial join (join one to many), but with around 400 points for each of the two lines this just results in a line with attribute table consisting of around 400 20km rows with different z values.
Thank you for your time, Dan.
Z values are contained within the Shape field... is the shape field a pointz type?  If it is, then you can get the values for Z by adding a field and using the field calculator to retrieve it or use this
Add Geometry Attributes—Help | ArcGIS for Desktop
SBreckan
I should have mentioned that I have already added the geometry attributes for the line, the points had them in the attribute table to start with. The line however, is Polyline and not Polyline Z so I cannot fetch elevation data from it.
NeilAyres
Probably, your only solution is to build a polylineZ from the points via arcpy / python.
If you give us a look at your point data, I am sure someone can give you a start to help you do this.
SBreckan
That would be great, I am not so well-known with the use of python. I have attached the point data to the original question.
NeilAyres
You have left most of your shapefile behind.
There is only the *.shp. Can't do anything with that.
A shapefile has several components *.shp, *.sbx, *.dbf, *.prj and possibly several others.
What do you mean by inbound & outbound?
SBreckan
Yes, I loaded those files up a bit too quick I see. Inbound and Outbound are just the names of the two lines.
It would be useful if you zipped the shapefile bits as one file so people don't have to download and unzip the individual components
