WAB: change size of Edit popup window ?
3392
09-15-2016 07:49 AM
helenchu
I'd like to make the Edit popup window a lot smaller so it won't block much of my map view.  I played with a few numbers in Widgets->Edit -> style.css but it doesn't work.
I'd also  like to change the word "Close" to "Save & Close" on the attribute edit button.  I can't locate it.
Thank you.
RobertScheitlin__GISP
Helen,
   You can adjust the size of a widgets panel by adding a width and height property to the main config.json depending on which theme you are using.
Helen,
  The edit popups size is controlled by the edit Widget.js file on line 500:
this.editPopup.resize(500, 251);
and the string "close" and be changed in the widgets nls\strings.js
close: "Close",
helenchu
I got the text "Close" changed.  For the editPopup size, I probably used the wrong name for it.  What I'd like to have the size reduced is the (spatial) feature edit template/window not the attribute window.
resize the attribute window only.
Thank you Robert
Helen,
helenchu
I got it!  Thanks Robert.
