Get ArcGIS for Server System folder from SOI
3510
7
09-11-2016 11:14 PM
JoseSousa
How can I obtain the ArcGIS for Server System Folder from within a Server Object Interceptor (SOI)?
The folder I am looking for is:
C:\arcgisserver\directories\arcgissystem
I need to get access to the arcgisuploads folder and would like to do that dynamically by asking ArcGIS for Server what is the configured location of the arcgissystem folder.
Can you share this information?
Cheers,
Jose
nicogis
var se4 = this.ServerEnvironment as IServerEnvironmentEx;
                    var dirInfos = se4.GetServerDirectoryInfos();
                    dirInfos.Reset();
                    object dirInfo = dirInfos.Next();
                    while (dirInfo != null)
                        var dinfo2 = dirInfo as IServerDirectoryInfo2;
                        if (null != dinfo2 && dinfo2.Type == esriServerDirectoryType.esriSDTypeSystem)
                            string pathSystem = dinfo2.Path;
                            break;
nicogis
                    dirInfos.Reset();
                            break;
JoseSousa
Hi Domenico,
Thanks for sharing. Much appreciated.
The line below causes a COM error:
The error is:
{"Unable to cast COM object of type 'System.__ComObject' to interface type 'ESRI.ArcGIS.Server.IServerDirectoryInfo'.
This operation failed because the QueryInterface on the COM component for the interface with IID '{CF180145-BCFE-4D6F-AC53-3B9E127AF840}'
failed due to the following error: No such interface supported (Exception from HRESULT: 0x80004002 (E_NOINTERFACE))."}
Have you tried this in ArcGIS for Server 10.4.1? The account running is an admin of course. I wonder if Esri changed this in 10.4.1?
The dirInfos.Count works though ...
Cheers,
Jose
nicogis
Hi Jose, I have tried and in 10.4.1 I have same error. Peraphs it's a bug.
In fact if you see code sample Esri (Watermark) in sdk 10.4.1  I see comment '//interop problem' and try/catch ....
try
                    //interop problem?
                    var se4 = _restSOIHelper.ServerEnvironment as IServerEnvironmentEx;
                    dirInfos.Reset();
                        if (null != dinfo2 && dinfo2.Type == esriServerDirectoryType.esriSDTypeOutput)
                            _outputDirectory = dinfo2.Path;
                            break;
                catch (Exception ignore)
                    _outputDirectory = string.Empty;
                _outputDirectory = _outputDirectory.Trim();
                if (string.IsNullOrEmpty(_outputDirectory))
                    _serverLog.LogMessage(ServerLogger.msgType.error, _soiName + ".init()", 500, "OutputDirectory is empty or missing. Reset to default.");
                    _outputDirectory = "C:\\arcgisserver\\directories\\arcgisoutput";
JoseSousa
Hi Domenico,
Thanks for coming back to me.
I will accept your initial response as Correct and wait for Esri Inc. to fix the issue.
Cheers,
Jose
MaximilianGlas
Actual Version 10.6, and this problem is still not fixed.
by Anonymous User
Not applicable
Uploads directory located on Drive installed location C:\arcgisserver\directories\arcgissystem\arcgisuploads
RebeccaStrauch__GISP
If you decide that you would like to see an option in python, or can use this to convert....
I'm doing something similar in python to find the physical path for the arcgisinput directory which is on my 😧 drive.  I get it by reading the info from the arcgisinput.json file located in the default C:\arcgisserver\config-store\serverdirs folder.  You should be able to do the same from the arcgisuploads.json file.  But sorry, only have it for arcpy/python.
In general, in python..
import sys
import os
import json
from pprint import pprint  # prints json pairs in readable format
import arcpy
server = "machinename"
serverPath = (r"\\{0}\c$\arcgisserver".format(server))
configInDir = os.path.join(serverPath, "config-store", "serverdirs", "arcgisinput.json")
# from arcgisinput.json file, determines the physical path of the services folder
with open(configInDir) as data_file:
     data = json.load(data_file)   #if issue in python 3.x, look at json.loads as option
     PhyPath = data['physicalPath']
     RelPath = (os.path.splitdrive(PhyPath)[1])
     #servicesDir = (r"{0}{1}".format(uncpath, RelPath))
     pprint(data)  # For debugging, to print out the .ini info
...you would have to update and test for the uploads file and convert it for your use.
