Editing a shared hosted feature layer
4955
12
09-04-2016 02:16 PM
MarkCederholm1
I'm experimenting with a hosted feature layer in AGOL.  When it's shared to everyone, if I open it in a new map with full edit control, the add feature tool doesn't work, and any edits I make won't take.  When I unshare it, then everything works fine.  Is this normal behavior?
ChrisWhitmore
Hi pierssen - are you using Google Chrome for your browser when you see this? Can you try a different browser (Internet Explorer, Firefox) and see if you are able to reproduce the behavior? It sounds like a bug Chrome introduced with version 52.
Chris
by Anonymous User
Not applicable
Are you given write permission to all open users or only you have..
Please check for feature services permission issue..
its depends upon your feature layer security permission(R/W).
MarkCederholm1
Editing is not enabled.  I'm editing it as an administrator.
by Anonymous User
Not applicable
can you share your layer URL...
MarkCederholm1
Here it is:  http://www.arcgis.com/home/item.html?id=bc6bf5d505994ff58c3b3bc41e841faa
I tried creating another layer and ran into exactly the same problem.
by Anonymous User
Not applicable
Thanks! Let me check
by Anonymous User
Not applicable
Check this
https://services7.arcgis.com/gs4zJBOmcfzAYvhS/arcgis/rest/services/Smart_Community_Survey__Avinash_P...
for your layer editing facility is not enabled.
Please check
PanagiotisPapadopoulos
if you see on the rest end point
http://services.arcgis.com/oaUiUItSLQlLIzjm/ArcGIS/rest/services/ffreds_Reviews/FeatureServer/0
the editing capability is not enabled
Publish again the layer as hosted feature service enabling the editing capabilities
see the result here
http://justamap.maps.arcgis.com/home/item.html?id=10c81144a3e24aa898d249adfab0b950
MarkCederholm1
I don't want editing enabled: that is by design.  However, I should be able to edit through AGOL as an administrator.  Again, read my original post.  Editing works fine for me when the layer is not shared to Everyone.
