How can I open a hyperlinked file by simply clicking on the attribute table (the file path) of the file rather than on the feature itself?
975
09-02-2016 02:47 AM
Elijah
I have several points, some collocated, visualized using Arcmap. Necessary data for these points are stored on my computer HDD. These files have been successfully hyperlinked to the point features. However, this points are so many and sometimes co-located that it is not easy to choose a point from the map to call up the hyperlinked files using the hyperlink feature. I was wondering if it's possible to call up the hyperlinked files by simply clicking on the hyperlinked file path as contained in the attribute table?
I hope some one will lead to the right direction.
Thanks.
DanPatterson_Retired
There is no capability, but you can check the hyperlink documentation for yourself
