LocalLayer Issue Labeling a Point
1839
7
09-01-2016 09:18 AM
AnthonyDaniels
I am having an issue with a point feature layer not showing a label using the LocalLayer widget?
RickeyFight
Do you have any errors in your console log?
Can you share the layer so we can try it?
AnthonyDaniels
No errors in the log that I can tell.
Here is the link to the service:
http://maps.co.forsyth.nc.us/arcgis/rest/services/TEST/TaxPointsLabels/MapServer/0
RickeyFight
In the Readme it says that you may need to add the showLabels option
```javascript
 "map": {
 "mapOptions": {
 "showLabels":true,
 "extent": {
AnthonyDaniels
It is setup that way just like the instructions, but still not showing labels for the point
RickeyFight
Are the points showing up? Just not the labels?
AnthonyDaniels
No problem with the points, just the labels
AdamDrackley
Just a note that I was able to get labels to display on a Feature Layer made from your service via the LocalLayer widget, Anthony.  Note that I did have to add that "showLabels":true value in the config.json file of the completed app as so:
"mapOptions": {
"showLabels":true,
"extent": {
"xmin": -8923741.74197918,
"ymin": 4324631.992240296,
"xmax": -8923478.98969453,
"ymax": 4324889.370046397,
"spatialReference": {
"wkid": 102100
Note that showLabels belongs within the mapOptions segment.  Also note that hitting 'Save' on the app in the builder appears to blow away the value if you haven't set it in your stemapp config.json file, so always make sure to re-add this showLabels value whenever you hit 'Save'.
