Export to BMP using arcpy missing shapefile problem
1282
08-31-2016 11:59 AM
LloydBronn
When exporting my map to BMP using arcpy one of the shapefiles is no longer visible. When exporting manually (File/Export Map) the layer shows up perfectly. I tried setting the exact same parameters inside the ExportToBMP to match the parameters from the manual export, but still no luck. I also manually exported the 'problem layer' using Export Data and that fixed the problem, but when I tried to mimic the Export Data process using FeatureClassToFeatureClass with arcpy I still had no luck. Any help is greatly appreciated, thank you! I have also tried using export to PDF and PNG, but still have the same issue.
DanPatterson_Retired
details of the issue undoubtedly lie in the code... which you can share, just ensure you are using the syntax highlighter
