Feature Request: Closest Feature
2048
08-25-2016 05:53 PM
MichaelDavis3
Any chance we could get an additional capability in the SDK to return the closest feature in a AGSGDBFeatureTable for a given point?
Right now the only way I can figure out to do this is to do a measure to every feature and find the shortest distance.  This is rather expensive, especially if you are working with a large address point layer or roadway stations.
Things can be more efficient by first creating a buffer of X distance from your location, selecting all points within the buffer, then calculating the closest feature from that subset... but it's still a rather complex undertaking for something that is pretty standard fare for GIS.
Also - what's up with the Quartz Beta?  Any update on when that bad boy might be ready for production?
DanPatterson_Retired
the power of advertising https://community.esri.com/ideas/12497
by Anonymous User
Not applicable
You can use network analyst extension tool to calculate all this.
create model in model maker and the GP services.
Closest facility analysis—Help | ArcGIS for Desktop
MichaelDavis3
Yes but this cannot be done on the device and requires a network connection.
