How do we limit choice list on print widget on web app builder?
1760
08-25-2016 02:51 PM
SubodhDhakal1
I  want to limit the printing choice list to PDF, JPG, but when i untick the  other options on publishing export web map as gp services, it defaults to all the choice list when i check on service? Any help why its not doing what we tell it to do when publishing export web map on ArcGIS Server
JonathanQuinn
Esri Notable Contributor
What version are you using?  There is a little note about those options within the 10.3 and 10.4 help:
Tutorial: Publishing additional services for printing—Documentation (10.3 and 10.3.1) | ArcGIS for S...
Tutorial: Publishing additional services for printing—Documentation | ArcGIS for Server
Caution:
Due to a known limitation with the Export Web Map tool, you cannot filter the parameter choices available to end users.
SubodhDhakal1
Thank you for your advise Jonathan. I wanted to limit my choice list to PDF, JPG and PNG32 on webappbuilder print function. I have achieved this with editing on print.js file under widget>Print>Print.js .
Also to get rid of the line separator between two choices, entered this code (to remove menu separator) on index.html file
with doing that I achieve this: Nice and tidy.
Thanks!
JonathanQuinn
Great workaround, thanks for sharing!  It'll definitely help other people with the same issue.
