PrintTask uncaught TypeError: Cannot read property 'query' of undefined
2445
08-16-2016 08:25 AM
Alexwang
Hello I was able to generate a thumbnail image using PrintTask from a WAB widget via http://mycomputer:3344/webappviewer/?config=sample-configs/config-demo.json. But after I added the widget to one of my apps using WAB dev edition. i got an error below
Not sure why it worked through the custom widget testing url but didn't work after I added it to my application. Can you please help?
_printTask: null,
_printTaskParams: null,
_thumbnailHeight: 200,
_thumbnailWidth: 200,
_thumbnailDpi: 96,
_thumbnailFormat: 'PNG32',
_templateLayout: "MAP_ONLY",
_preserveScale: false,
_showAttribution: false,
_exportWebMapTaskUrl: 'http://sampleserver6.arcgisonline.com/arcgis/rest/services/Utilities/PrintingTools/GPServer/Export%2...',
_initPrintTask: function(){
      this._printTask = new PrintTask(this._exportWebMapUrl);
      var template = new PrintTemplate();
      var params = new PrintParameters();
template.exportOptions = {
   width: this._thumbnailWidth,
   height: this._thumbnailHeight,
   dpi: this._thumbnailDpi
template.format = this._thumbnailFormat;
template.layout = this._templateLayout;
template.preserveScale = this._preserveScale;
template.showAttribution = this._showAttribution;
params.map = this.map;
params.template = template;
        this._printTaskParams = params;
_createThumbnail: function(){
this._printTask.execute(this._printTaskParams, lang.hitch(this, function(result){
      this._storeThumbnailUrl(result.url);
Tags (1)
RobertScheitlin__GISP
Alex,
   You have to edit your ArcGIS Servers "Site" page and find the output directory and change the max file age (default 10 minutes).
Alex,
   You included some code and a screen capture of the error but that is still not enough for me to figure out the error. Can you provide more?
Alexwang
Thanks Robert. My fault, I used the wrong name for the PrintTask url. I was able to make it work now.
Another question i observed was that the ArcServer GP service keeps the map images only for a short time. Can I change somewhere on ArcServer side to keep the thumbnail images longer? Basically my widget uses a reference to link to these thumbnail images.
Alex,
