WAB 2.1: attribute table: click on row to highlight feature will remove that feature from selection set
1084
08-11-2016 12:35 PM
helenchu
Hi
WAB 2.1:
I use query widget, then 'view in Attribute Table'
From Query Result attribute table, if I click on row to select/highlight a feature, it will remove that feature from the Query Result attribute table.  (The query result from the query popup window stays the same, nothing got removed).
Is this an expected behavior ? is it a bug ?
Thank you
RobertScheitlin__GISP
Helen,
  It feels like a bug to me. You will need to call esri tech support and report this issue.
