Web App Builder Add Data Widget: From File
2783
08-08-2016 09:18 AM
ToddHenry1
Can you use the new add data widget to browse to a file to upload a CSV or do you have to provide a URL?
Tags (1)
RobertScheitlin__GISP
Todd,
  The help docs only mention support for urls. There is no file dialog support in this widget.
DavidColey
MVP Frequent Contributor
Hi Robert, now that the AddData widget at 2.3 allows adding from file, have you had a chance or the curiosity to see if the number of records in a zipped shapefile can be increased? Currently the limit is set to 1000, which sounds familiar, but I haven't been able to detect if that can be changed-
David
David,
   No I have not. Actually I rarely use shapefiles no a days, since map packages are the more modern standard for exchanging data and map as one file.
DavidColey
Sure sure, I'm with you.  Customers you know . . . but thanks.  If I find anything I'll post
