WebApp Panels not showing
488
08-08-2016 08:19 AM
MB4
Hi All,
I have 2 widgets that I'd like to open in a (for example a blue panel)... at present they both open in separate blue panels.
I'd like to have them both open in 1 blue panel only... this doesn't seem very easy to do. I have the widget in a group which also lists the blue panel to open them with maxWidgets set to 2.
Any quick ideas on what I may be doing wrong?
RobertScheitlin__GISP
M B,
  Have you seen the docs on grouping widgets in a panel?
Widget—Web AppBuilder for ArcGIS (Developer Edition) | ArcGIS for Developers
You can also group in-panel widgets by dragging one or more widgets into another widget. The grouped widget shows as a folder icon on the controller widget. To ungroup the widget, drag each widget out of the group.
