Error adding .csv to My Content
3053
7
08-03-2016 12:16 PM
BrianBrady5
Hello, I am trying to add a .csv to My Content.
My Content > add item > From my computer > "traffic_counts.csv"
When I do so it returns "there was an error" with no more information:
Here is a sample of my .csv file:
If you have any insight it would be greatly appreciated. Thank you.
DanPatterson_Retired
it looks like a spreadsheet.... open the csv file in a text editor and as a suggestion you shouldn't use field names with spaces in them or other unsavoury characters.
BrianBrady5
I removed the spaces, here is screenshot of the .csv opened in a text editor:
I receive the same error. Thank you for your time.
well, I hope it isn't the case of lat and long, they cite Latitude and Longitude but that would be just plain dumb.  However there is a litany of requirements any of which you will have to confirm.  Hopefully you don't have dates cause you will be there for a while... addresses are an issue as well
CSV, TXT, and GPX files—ArcGIS Online Help | ArcGIS
BrianBrady5
Yes, I will need to format this properly. However, i am further confused in that it won't allow me to upload something like this:
I was questioning where the case of the coordinae field was important.. but if you haven't been able to add anything thaen it is a different problem
JosiahCorona2
Have you federated your server and selected a hosting server? I'm assuming you are working with portal.
BrianBrady5
I am not familiar with Portal. I have an arcGIS for developers account. This account should give me permission to To web-enable feature layers from CSV files, correct? I believe I have everything set up and running. I am able to create simple web apps locally with the WebAppBuilder on top of Node. I apologize for any ignorance, I am very new to GIS.
