Creating a space time cube, problem saving the output space time cube, help?
1616
08-02-2016 02:15 PM
SiobhanDancey
This may be simple and I'm missing something. I'm trying to create a space a space time cube. The menu though, requires me to select a file to save the output space time cube. The only option here for file type is 'file' which is not the netCDF required, but this does not appear as an option and I'm not sure how to enable it as an option.
Also, in terms of creating a template space time cube on which to run my analysis I'm not sure if there is a separate section to do this?
Any help/advice/direction is greatly appreciated.
Thanks for your time
DanPatterson_Retired
