Arcgis Online script to get user connection detail
3276
6
08-02-2016 05:08 AM
FlavieMORAUX1
Hi Everyone,
I have a question about arcgisonline scripting (python/api rest). Are there any way to retrieve the list of connections for a given user? Or the count of connection?
This will allow me to see if my users uses frequently arcgis online, or not.
I see it neither in ArcGis Python API nor in ArcGIS API REST.
Thanks in advance.
Flavie
AlexanderBrown5
Flavie,
You can check out Tom Swanson's AGO get Info.  You will need visual studio of some sort to open and run.
GitHub - tswanson/AGOgetInfo: Output all AGO content for Org to a csv file
I have seen this in action and believe it is exactly what you are looking for.
Regards,
Alex
FlavieMORAUX1
Alex,
Thank you for the answer.
I have some problem when using tool (Could not establish trust relationship for the SSL/TLS...). It's propably related to my proxy?
I will try from my home, so without proxy.
Wait and see...
Flavie
FlavieMORAUX1
Hi Alex,
I success to run the tools, but i don't get needed information.
The tool just return :
- account creation date
- account modification date.
Thanks anyway,
Flavie
KellyGerrow
Esri Alum
You can query this information using the users call in the rest API:
ArcGIS REST API
There are returned parameters for date created, date modified and last login.
-Kelly
FlavieMORAUX1
The problem is that I want the list of all connections for a given user, not only the last date. Actually, I want to calculate a connection frequency indicator.
Otherwise another solution, call API REST every day.
FlavieMORAUX1
Hi Kelly,
I study API REST method User and I have a question about it. Property "lastLogin" return the last login date, but sometime it return "0" or "-1" value when user has never logged. So what is the difference between "0" and "-1".
Flavie
