Cascade: When adding an immersive section cannot see layers of webmap
1658
07-20-2016 10:54 AM
RodC
When I am adding an immersive section to the cascade builder, and add a webmap, none of the layers load, it's just a blank map just the basemap, no scale dependencies. Tried sharing both the story and webmap publicly and that did not work either.
Any help would be great!
OwenGeo
Esri Notable Contributor
Hi Rodrigo,
When you add a map and are view the Appearance tab of the configuration panel you should see a table of contents at the top right that will let you toggle layer visibility. Let me know if you see that or not.
See this blog for more info: Using the Story Map Cascade Builder: Configuring Media | ArcGIS Blog
Owen
Owen Evans
