Error message when creating feature layer in AGOL
4310
07-19-2016 09:54 AM
SamanthaO_Neil
I keep getting this error when trying to create a feature layer from a url in AGOL.  "This service type is not supported. Please specify a URL to a feature layer. The layer must include FeatureServer in the URL"
Has anyone seen this before? I created feature layers using the same rest url path a couple months ago without error.
-S
KellyGerrow
Esri Alum
HI Samantha,
The service which is used as a reference will need to have feature access enabled. When adding the service, ensure that you use the /FeatureServer Url.
Kelly
KellyGerrow
Esri Alum
Hi Samantha,
Can you share the url that you are trying to add?
A few questions:
1. Are you adding a feature service url?
2. Are you using a feature service that has https enabled?
I would also recommend reaching out to Esri Technical Support​ if you want someone to troubleshoot the issue with you.
-Kelly
SamanthaO_Neil
Hi Kelly,
1. I figured it probably had something to do with checking the "Feature Access" capability in my map service. (Currently having an issue registering my data folder.)
But here is a URL of a feature layer I currently have set up but now I get the above error if I use it to create a new feature layer:
http://gisserver2012/arcgis/rest/services/AGOL/GreeneCounty_Basemap/MapServer/0
It does not have "Feature Access" capabilities.
2. We are not using the https security option at this time.
Thanks for the response.
-S
KellyGerrow
Esri Alum
HI Samantha,
Kelly
