Clip Raster based on Shp with same name
1788
07-18-2016 08:49 AM
StevenGraf1
Occasional Contributor III
Does anyone know of a script that will iterate rasters and grab its associated shapefile (same name as raster) and clip using the two inputs?
Basically I have:
Raster1, Shapefile1
Raster2, Shapefile2
Raster3, Shapefile3
Raster250, Shapefile250
I've seen some basic clip scripts that use ListRasters to iterate through rasters.
Batch Clip in ModelBuilder of ArcGIS for Desktop? - Geographic Information Systems Stack Exchange
I figured this most likely can't be done in Model Builder or can it?
Steven
StevenGraf1
I wrote a small script that on first test runs seems to accomplish what I need.  I will run a few more tests and post the script.
-Steven
StevenGraf1
Here's my script.  I converted it to a toolbox.  To import to a toolbox, save it as a file (example:  AdvanceClip.py [make sure the .py is on the file name]) Right click a toolbox and Add Script, then set 3 parameters 1) Input GRIDs 2) Input Polygons 3) Output Directory.  Set them all as workspaces. This script assumes your polygons are named exactly the same as the grid files you will be clipping.  If your output directory is a folder, your file names can't be longer than 13 characters.  It's best to output to a geodatabase.
import arcpy
# Set the current workspace
arcpy.env.workspace = arcpy.GetParameterAsText(0) #"D:\\Test2\\Grids.gdb"
#Polygon Shapefiles Workspace
clipFeatures = arcpy.GetParameterAsText(1) #"D:\\Test2\\Shps\\"
#Output Directory
outDirectory = arcpy.GetParameterAsText(2) #"C:\\Users\\sgraf\\Documents\\ArcGISData\\Test2\\Outs.gdb\\"
# Get and print a list of GRIDs from the workspace
rasters = arcpy.ListRasters("*", "GRID")
for raster in rasters:
    arcpy.AddMessage("Clipping " + raster + " with " + raster + ".shp")
    desc = arcpy.Describe(clipFeatures + "\\" + raster + ".shp")
    extent = desc.extent
    arcpy.Clip_management(
    raster, str(extent), outDirectory + "\\" + raster, clipFeatures + "\\" + raster + ".shp", "#", "ClippingGeometry", "NO_MAINTAIN_EXTENT")
-Steven
DanPatterson_Retired
Do you want me to convert this series of posts to a discussion?  There is little point asking and answering since you are the only one that contributed.  Let me know
StevenGraf1
Go for it, Thanks!
