QML NOT FOUND - Error - Quartz
2095
07-15-2016 01:15 AM
MathanManohar
I had installed the Qt 5.6/ArcGIS Runtime 10.2.6/Quartz [ArcGIS Runtime 100.0.0].
I would like to create an project for loading .mmpk in mobile apps.
I choose ArcGIS Runtime 100.0.0 Qt Quick Application, named the project, selected the kit. facing an error
import Esri.ArcGISRuntime 100.0 shows with redline error. Stating "QML NOT FOUND".
Thanks in advance.
Tags (1)
LucasDanzinger
Esri Frequent Contributor
Hi Mathan,
All beta questions should be logged in the Early Adopter Community. I'll give you a suggestion here for something to try, but please continue the discussion by creating a new post in the Early Adopter Community - https://earlyadopter.esri.com/home.html
I suggest that you ensure you have run the post installer for the kit that you are trying to run this against. It sounds like the QML plugins did not end up inside the Qt kit you are building with.
Luke
