Exponentially changing attribute in a function in CGA rule
3288
07-05-2016 09:38 AM
GeorgiosAnastasiou
In a CGA rule I have a repeating function that needs to be changing the set attribute value exponentially and not proportionally as I have it now. One way to do it could be by setting an attribute inside the function (like in python), but it is not supported. What would be a way of doing that?
LR
You mean something like this?
attr RowRow = 2
attr Expo = 2
attr HoldMe = 0
Lot -->
extrude(5)
color (1,1,0)
print("----------")
DoTheThing
DoTheThing -->
case Expo > 10: EndThis
else: GoGo
GoGo -->
print("Expo old: " + Expo)
set(HoldMe,pow(RowRow, Expo))
set(Expo, Expo+1)
print("Expo new: " + Expo)
print("Exponential!: " + HoldMe)
print("--")
DoTheThing
EndThis -->
#important
print(":D-/-<")
print(":D-\\-<")
print(":D-/-<")
print(":D-\\-<")
print(":D-/-<")
print(":D-\\-<")
print(":D-/-<")
print(":D-\\-<")
GeorgiosAnastasiou
for example in this case, you can apply it in any footprint and see the shape:
attr Factor = 0.97
attr Depth = 0.01
attr Stop = 0.1
Lot-->
   extrude(Depth)
   center(xyz)
   X
   comp(f) {top : Levels}
Levels-->
   case(scope.sx > Stop) :
      s('Factor, 'Factor, 0)
      center(xy)
      extrude(Depth-0.02)
      X
      comp(f){top : Levels}
   else:
      NIL
The target is in each repetition the attribute "Factor" to be smaller than the previous one. So, the higher the floor, the smaller the size becomes exponentially.
Edit: it should work as I want it with
attr Depth = 0.1
LR
attr RowRow = 2
attr Expo = 2
attr HoldMe = 0
Lot -->
extrude(5)
color (1,1,0)
print("----------")
DoTheThing
DoTheThing -->
else: GoGo
GoGo -->
set(Expo, Expo+1)
print("--")
DoTheThing
EndThis -->
#important
print(":D-/-<")
print(":D-\\-<")
print(":D-/-<")
print(":D-\\-<")
print(":D-/-<")
print(":D-\\-<")
print(":D-/-<")
print(":D-\\-<")
GeorgiosAnastasiou
That was very useful, and by following the log in CGA console I understood exactly how it works.
I found exactly what I needed: the "set" operation to change the attribute inside the function, and the exponential growth of the value, in this case by using the "pow" (power) operation.
Thank you very much Z R!
