Error when trying to view table on ArcGIS online
2189
06-27-2016 03:29 PM
DanbiLee
Hi everyone,
recently synced a few maps from ipad to AGOL, which use the same web feature service. In AGOL I the added a new field in the table view. After I clicked "add new field" it threw an error that it could not access the data. I tried to view the webmap in ArcMap and still it can't access data. I have a feeling this has to do with the fact that I added a new field on AGOL and because there are other maps on the ipad that haven't been synced, there's some sort of replica conflict. How can I troubleshoot this? Even if i wanted to remove that new field, I can't as I can't access the table itself.
THanks
KellyGerrow
Esri Alum
Hi Danbi,
You can always contact technical support for help troubleshooting the issue.
A few questions:
1. Are you the owner of the hosted feature service?
2. Can you open the feature service in a new web map and see the field?
3. Are you able to see the data in your web map before you open the table?
Kelly
