Map Data Not Yet Available?
5734
06-22-2016 12:05 PM
DavidForbuss1
Ever since the latest AGOL update I keep getting the error "Map Data Not Yet Available" when I zoom in past a certain point.  This is only happening in the web app (1st pic).  When I view the webmap that is feeding into the app, I can zoom in as far as I want without getting the error (2nd pic).  It's happening no matter which basemap I use too.  Anyone know what might be causing this?
When viewed in the webapp:
Same location, but viewed in the webmap (that feeds into the app):
Tags (1)
KellyGerrow
Esri Alum
Hi Dave,
Thanks for reporting the issue. This issue is going to be fixed tonight. Please check the app tomorrow and let us know if the issue is solved.
-Kelly
KellyGerrow
Esri Alum
Hi David,
What basemap are you viewing? Also, are you able to share your web map and app that is receiving the errors?
-Kelly
KellyGerrow
Esri Alum
Hi Dave,
-Kelly
DavidForbuss1
Awesome!  Thank You Kelly!
DavidForbuss1
I just checked and everything's working great .
