Allow attaching custom HttpMessageHandler to requests
3152
06-20-2016 09:16 AM
Espen_RøvikLarsen
Being able to hook into the HTTP pipeline is an important concept in the System.Net.Http architecture.
My need is processing outbound requests and attaching an OAuth2 token. I am hiding AGS behind a proxy which use Oauth2.
Hope you can add this feature in a future release. Thanks
dotMorten_esri
Esri Notable Contributor
This is on our list for the Quartz release and can hopefully deliver something that supports your use case. To ensure it's covered could you share more specifically what you want to inject, and perhaps even how you would like to do it?
Espen_RøvikLarsen
Great to hear.
The code would add an Authorization request header with value "Bearer <token>". Standard OAuth 2.0 stuff - nothing fancy. The proxy reads the Authorization header and validates the request before passing it on to AGS - attaching an AGS token to it.
I have actually written this part open source as middelware for ASP.NET Core.
GitHub - espenrl/erl.AspNetCore.AgsToken
dotMorten_esri
So if I were to give you a global delegate method you can assign that is called on each and every request the runtime makes, and you get a reference to the HttpRequestMessage right before it goes out. you can then (synchronously) modify it, ie add a header (and for instance only it if it matches a specific URL), that would work for you? I assume you don't need async support here? (I would be reluctant to allow for async support, since we don't want to introduce too much overhead at such a low level) ?
I assume you don't need support for handling the response? (if you get an authentication error, the runtime should raise an authentication required event where you can handle that already anyway)
Espen_RøvikLarsen
I do not need to handle the response in my case, no.
Async support would be nice. For the most time the request would be synchronous (due to a cached token) and every hour doing an async call to the identity server (our OAuth token lasts for an hour). Making the API having a synchronous API surface would not stop me doing a blocking call anyway. 🙂
Are you thinking of the overhead of the compiler generated state machine?
The ultimate solution would be attaching a custom System.Net.Http.HttpMessageHandler to the ArcGISHttpClient.
Extending HttpClient with OAuth to Access Twitter | Henrik's Blog
