Parsing text file and output to text file or csv
9464
6
06-20-2016 08:46 AM
KushendraShah1
Hi
I have a gps text file that has coordinates with other variables. I need to parse the file in order to get Lat, Long and Altitude values from the file and write it into new text file or csv. I tried to read the lines but I got error like this:
Here is my code:
# This script reads a GPS data and prints a list of coordinate pairs
import csv
# Set up input
gpsdata = open("C:/testdata/telemetry2.txt", "r")
# Set and process CSV reader
csvReader = csv.reader(gpsdata)
header = csvReader.next()
latvalueIndex = header.index("lat")
lonvalueIndex = header.index("long")
altvalueIndex = header.index("alt")
# Make an empty list
coordList = []
# Loop through the lines in the file and get each coordinate
for row in csvReader:
    lat = row[latvalueIndex]
    lon = row[lonvalueIndex]
    alt = row[altvalueIndex]
    coordList.append([lat,lon,alt])
# Print the coordinate list
print coordList
I have also attached the data sample. I will appreciate for any help to get this fixed. Thanks
RebeccaStrauch__GISP
Do you have NotePad++   (free Notepad++ v6.8.2 )
You can easily replace the tabs with commas with that.  There are also ways to do it with Word (a tab is ^t I believe).
Or in python
aRecord.replace("\t", ",")
DanPatterson_Retired
well there are no commas for the csv (comma, separated values) reader to separate on.  Can you not just parse this using spaces?
KushendraShah1
Dan, the data is tab delimited, the script works when you insert commas between columns. I was thinking if there is solution that directly read and write tab delimited data or like this type. Thanks
well a spreadsheet can, but I presume you tried that already, otherwise you will have to parse on the tabs
Or in python
TedKowal
Honored Contributor
Would this be of any help? ..... I have use this for tab delimited files (excel style).
13.1. csv — CSV File Reading and Writing — Python 2.7.12rc1 documentation
Just be sure you have:
1. No ASCII Null Data
2. UTF-8 Format or ASCII printable  delimiters
import csv
reader = csv.DictReader(open('somefile.txt', 'rb'), delimiter='\t')
for row in reader:
  #do something more useful here
  print row.get('new')
KushendraShah1
Thanks Dan Petterson, Rebecca Strauch and Ted Kowal for your inputs. Appreciated. It is solved now.
