copy feature from one layer to another
2564
06-19-2016 12:14 AM
cadgism
I have two feature  layers layer1 & layer2. I want to copy a feature from layer1 to layer2  and chnage its attributes as per layer2. I had already created a graphic from layer1. Layer2 is published as  Featureservice.  What I am trying to do is select the feature from Layer1 as graphic, and trying to do ApplyEdit (graphic to Layer2) is this the right way? But it fails. I meanLayer2 is not updated in the Geodatabase. I am using the following code to make the edits,  as suggestion from ArcGIS javascript forum Girish Yadav.
var newFeature = new Graphic(graphic.toJson());
featureLayer.applyEdits([newFeature], null, null) The
Environement : Javascript API 3.16 ArcGIS Server 10.0 ArcSDE GeoDatabase 9.2 Oracle database 10.2.0.3
