Loading a File geodatabase on the Server
1761
06-14-2016 12:22 PM
PennySawyer1
I am trying to learn how to write scripts with Javascript. I have this book named " Building Web Applications with ArcGIS." They provided the data and the sources is file geodatabases. I have the data stored onto our network drive. I can publish the mxd with the file gdb on to our server. However, i can not set the capibilities as feature access  when I go to share the map through ArcGIS Online as a web service. I have tested the script which works but I am unable to  see any layers when i run the script through chrome.
Is it possible to save the files as shapefile and publish to the server and then host theough ArcGIS Online. Below i have added a  code  the Author of this book has provided and how to add a map from the server into a javascript.
I asked people from Packt and they could not help.
<html>
<head>
<title>Bestaurants Web Application</title>
<link rel="stylesheet" href="arcgisjs/esri.css">
<script src="arcgisjs/3.10/init.js"></script>
<script>
dojo.require("esri.map");
function startup()
  //alert("map is about to load");
  //create the map object and load it into the 'mymap' div element
  var map = new esri.Map("mymap");
  //load the layer into an object
  var lyr = new esri.layers.ArcGISDynamicMapServiceLayer
  "http://arcgismachine:6080/arcgis/rest/services/Bestaurants/MapServer"
  //add the layer to map
  map.addLayer(lyr);
dojo.addOnLoad(startup);
</script>
</head>
<body>
<table border =1 width = '1000px' height = '700px' align =center>
<tr>
<td colspan =2 width='100%' height ='10%'>
  <!-- The toolbar where we will place tools -->
  The toolbar that contains useful tools to interact with the map and search for restaurants  <b> (100% width and 10% height) </b>
</td>
</tr>
<tr>
<td width='20%' height ='40%'>
  <!-- The legend of the map goes here -->
  The legend items go here <br> <b>(20% width and 40% height) </b>
</td>
<td width='80%' height ='85%' rowspan =2 valign = top>
  <div id='mymap' class='arcgismap' >
  </div>
</td>
</tr>
<tr>
   <!-- The search results will go here -->
   The search results goes here, we will display the search for the users in this box <br> <b>(20% width and 40% height)</b>
</td>
</tr>
<tr>
  <td colspan =2 width='100%' height ='5%'>
  <!-- The status bar for displaying messages goes here -->
  The status bar goes here  <b> (100% width and 5% height)</b>
  </td>
</tr>
</table>
</body>
</html>
