how to show pdf document on click
3202
06-14-2016 02:54 AM
SadanandacharB1
Hi All,
          I have one spatial table with attributes information and pdf name stored in it. On map click i am displaying the attribute information information in datagridview using identify task in arcgis javascript.
My problem is along with attribute information i have to display pdf document related to that feature which is stored in a server folader. Please show me some examples to do this.
Thanks!
FC_Basson
If the location of the PDF document is known in any of the attributes of the features, you can simply open it in a new window/tab:
window.open(pdfUrl, "_blank");
SadanandacharB1
Thanks FC Basson
   Can you give me simple example for this, i am new to javascript, can you please help me
FC_Basson
That is the example.  You just need to replace pdfUrl with the actual URL location of the PDF document, e.g. "http://myserver.com/data/feature1.pdf" (absolute pathname) or "/data/feature1.pdf" (relative pathname).  Follow the API instructions to retrieve information from your features with the IdentifyTask (API 3.16: IdentifyTask | API Reference | ArcGIS API for JavaScript , API 4.0: IdentifyTask | API Reference | ArcGIS API for JavaScript 4.0 ).
SadanandacharB1
Thank you so so so much
