Can't add attachments to offline map loaded from Portal 10.4
1364
06-13-2016 07:22 AM
JohnFranks1
In both Android and Windows 10, I'm unable to add photo attachments (from camera or from file) when using an offline map that was loaded from Portal 10.4.  However, I am able to save attachments while the tablet is online.  To make it more confusing, I loaded the same map onto to AGOL and had no problems with adding attachments while offline.  So it seems the problem may be with the configuration in Portal?  It's using ArcSDE and Microsoft SQL Server.  I'm using relationships classes, editor tracking, and domains, but the tables are pretty simple otherwise.  Any suggestions?  I don't see any settings I can change in the Portal pages, so is there something I can look for in the ArcGIS server settings?
Collector version:
10.3.7 build 1018
Portal 10.4
Android error:
The message "Unable to update feature" flashes briefly on the screen, then the message "Posting attachment" stays on the screen until I force close Collector.
Windows 10:
"Attachment failed to upload"
"One attachment failed to upload."
However, the app doesn't lock up like in Android.
I found this similar thread from 2015 that hasn't been resolved:
https://community.esri.com/thread/159516?q=android%20offline%20attachment
ZorbaConlen
Similar issue. My web map in on AGOL though. I'm seeing exact same behavior with my android device. And similar problem with iphone, but it does not cause the device to freeze up.
