SimpleFillSymbol style does not work
4650
06-11-2016 04:07 AM
DavidNascimento
Whenever I try to set a style other than 'solid' on a SimpleFillSymbol, the geometry gets rendered empty, with only the outline being drawn. Is this a known issue? I couldn't find any similar posts on this forum.
Best regards,
David
FC_Basson
How are you setting the style of the graphic?  See SimpleFillSymbol | API Reference | ArcGIS API for JavaScript
So for example, this works:
var graphic = map.graphics.graphics[0];  // first graphic of map graphics list (assuming it is a polygon)
graphic.symbol.setStyle(esri.symbol.SimpleFillSymbol.STYLE_HORIZONTAL);
map.graphics.redraw();
DavidNascimento
We are using JSAPI 4.0 and developing in Typescript. We tried setting the value in the constructor, afterwards, with and without specifying color - the result is the same. Nothing is rendered unless the style is 'solid'.
FC_Basson
Oh sorry.  Test the following on the Esri sample (Get started with graphics - 4.0 ) and it works:
polygonGraphic.symbol.style = "diagonal-cross"
FC_Basson
The description says thath the property is not supported for 3D SceneViews: SimpleFillSymbol | API Reference | ArcGIS API for JavaScript 4.0
