Solution for BUG-000086319.
8196
17
06-08-2016 07:17 AM
LianaSmith
Does anyone have any solution for the bug (#BUG-000086319 Numeric field types within the attribute table in the Web AppBuilder still show the thousand comma that were removed in the webmap in arcgis online)?
In my query results numeric field values have commas that I do not need.
DanPatterson_Retired
The most recent bug lists for arcmap are here http://downloads.esri.com/support/downloads/other_/1041-IssuesAddressedList.pdf for others, you will have to go to support and examine for previous versions and software.
MelitaKennedy
Esri Notable Contributor
What version are you using? I'm seeing that it was verified as fixed in February but that might have been too late to make the March 2016 2.0 release.
LianaSmith
i have both 1.3 and 2.0. This problem occur in both..
RobertScheitlin__GISP
Liana,
  I have tested in WAB 2.0 and I am not seeing this issue anymore.
LianaSmith
Robert, I checked again and even created new application, but still get the same ( at the query results some values have commas). I noticed that commas appear only for the values whose format is long integer.
Liana,
OK is this only happening with the query widgets results? If so then this is still an issue until the next release around UC time.
LianaSmith
Robert, it only happens with the query widget results..I have seen that you were giving help to someone else with some changes that could be done in the code. By any chance do you have similar option for WAB 2.0? or 1.3? Thank you!
"There is no configuration in place for this. But you can easily add code to handle this. Open the Query Widget.js file and around line 1131 replace:"
  1.               fieldValue = this._tryLocaleNumber(fieldValue);
with:
  1.               if(fieldAlias !== "Zip code"){
  2.                 fieldValue = this._tryLocaleNumber(fieldValue);
  3.               }
Liana,
  Are you now using the developer version?
LianaSmith
Yes! I had to import it to Developer Edition to be able to change the code
